Message 1 of 3
Recording programmes on freeview
Hi we are thinking of moving from Sky to BT TV.  The BT website says that BT TV comes with a box that can record programmes but says freeview channels are separate and through an aerial.
Just checking, can you use the BT TV box to record freeview channels ? There nothing about it on the website
2 REPLIES 2
Message 2 of 3
Re: Recording programmes on freeview
Yes - you can use your main BT TV box to record TV channels, including those that come via your TV aerial.
Message 3 of 3
Thanks Darren
