Message 1 of 4
TNT Cancelled Before End Date
Good Afternoon,
I recently cancelled my TNT sports subscription.  It's the rolling subscription, not the monthly pass.  It was paid up to the 3rd January and the cancellation email confirmed the service would stop on 3rd January.
I switched on today to watch TNT only to find out it's already been cancelled and I no longer have access.
Am I right in thinking this should not have ended until 3rd January?
3 REPLIES 3
Message 2 of 4
Re: TNT Cancelled Before End Date
Hello,
Your correct your service should of continued until 3/Jan/24 at 23:59pm.
you should notify BT so they can correct the billed so you will be owed some pro rota because of it.
hope this helps.
Hope this helps! 🙂 If you like my reply and
want to say thanks for the helpful answer
then please click on the Kudos on left hand
side 😉 also if I answers your question correctly please let us know by clicking on Mark as Accepted Solution 😄
Message 3 of 4
Thanks. That's what I thought.  I will get in touch with BT and get the bill adjusted.
Message 4 of 4
Not a problem glad I was able to help 🙂
