Message 1 of 8
TNT Sport
Hi lovely people,  Set up tnt sport - this is the message the LG TV tells me when I am using the set top box. Can anyone help please as I thought it would be set up already because I'm using the tv box.  Just don't understand?  Thanks anyone.
7 REPLIES 7
Message 2 of 8
Re: TNT Sport
Is that message coming up on all of the TNT Sports channels when you try to access them? Are you a new EETV customer? Do you have the HD/UHD add-on?
Message 3 of 8
Re: TNT Sport
I got that when I 1st signed up. What happens if you press OK - mine loaded in for me after that.
If not are you maybe on the HD channel and don't have the add on?
Message 4 of 8
Re: TNT Sport
If it is the LG TV telling you that it is likely to be telling you to set up their "Magic Remote" to control the set top box. If you are happy using the individual remote controls, then no need to do that.
Message 5 of 8
Re: TNT Sport
@Ladybeetle you have access to TNT Sports in SD, so have access to channels 408-411 and 450-455. Access any of these channels and you may be asked once to activate them by clicking OK, and then they'll just work in future.
Message 6 of 8
Re: TNT Sport
This seems to have worked -thank you.
Message 7 of 8
Re: TNT Sport
Thanks for your input.
Message 8 of 8
Re: TNT Sport
Thanks for your help.
