Message 1 of 3
TNT Sports HD isn't HD anymore
I'm trying to watch the UFC and the picture quality is awful. For the last month or so I've noticed the picture quality of TNT Sports is just not up to snuff.
I've had TNT Sports since it switched from BT Sports with both Virgin and BT, the quality of the broadcast has dropped off a cliff recently.
Watching the channel live is no different, the cycling, the football, just atrocious.
The SD channel is understandably bad but the "HD" channel has no crispiness to it either.
Has anyone else noticed this drop in quality?
Personally I think it's bad enough to show a contract cancellation but apparently I'd have to pay 300 odd quid to get out. That don't seem right.
2 REPLIES 2
Message 2 of 3
Re: TNT Sports HD isn't HD anymore
UHD broadcasts leave a lot to be desired but usually like the prem matches broadcast yesterday the HD offering is near perfection
Message 3 of 3
@gordiniroy  Which EETV  box are you using and if you go into Settings on the box  under Box Management thee is PIcture and Sound  what do you have your HDMI Display set to ?
