Message 1 of 5
TNT on HBO
Will we still be able to watch TNT on our BT TV box when it switches over?
4 REPLIES 4
Anonymous
Not applicable
Message 2 of 5
Re: TNT on HBO
Download the HBO app and sign in with your discovery plus credentials
Message 3 of 5
Re: TNT on HBO
I can't find anyway to do this manually but it does look like it will happen automatically on the day. Fingers crossed.
For EE TV Box Pro / Box Edge (Newer Boxes)
Automatic Update: The HBO Max app is designed to be automatically installed for these devices around March 26, 2026.
Manual Install: If it does not appear, go to the Apps section in the main menu to locate and select the HBO Max app to install.
Sign In: Use your existing discovery+ username and password to log in.
Message 4 of 5
Re: TNT on HBO
@MarkSimmons   Unfortunately there is a lot of conflicting information that appears when people search for information on the web.
If you are using a Box Pro or Box Edge  with EE or BT broadband  then it is expected that the HBO Max app will appear on your box on 26March. The apps available to you on those boxes are provided on the Home Page  …. So you should see it on the featured app or more likely the general app rail on the home page.
there is no App Store to  manually install or remove apps on those boxes you get the Home page and Apps that YouView determines is appropriate for your ISP , location and box type.
If you currently use discovery+ for streaming TNT sports on other devices you would need to use that device app stores to install HBO Max on or after 26 March.
Any viewing of TNT Sports linear channels via the EETV Box Pro or Box Edge EPG (guide) is not affected.
Message 5 of 5
Re: TNT on HBO
Thanks @zulu17 that's useful info for me.
