Message 1 of 4
Want suggestion for BT sports
Need suggestion for sports package.
I am interested to watch English premier league, champions league, Europa league and Serie A.
I cannot download BT app as my google store doesnt allow me. I can only watch these online using my laptop.
Please suggest the cheapest and best possible sports package for me !
3 REPLIES 3
Message 2 of 4
Re: Want suggestion for BT sports
What device are you trying to download the BT Sport app on?
Message 3 of 4
@SagarBora
are you resident in uk?
Message 4 of 4
I can see from your other post on these forums that you're a BT Broadband customer, so you have every option for BT Sport available to you - it all depends on how you want to watch it. Check all the options here: https://www.bt.com/sport/addbtsport
The cheapest is £18 a month. Either:
  • on BT TV, allowing you to record. This comes with a 2 year contract (plus a £39.99 set up fee).
  • App only - if you only want to watch using the app (including on Android TV if you have it) then there's no minimum contract and no set up fee.
Regarding your Android device - you just need to make sure your Google account is registered to the UK. You can find instructions for changing the Play Store country here: https://support.google.com/googleplay/answer/7431675?hl=en
Any device running Android 5 or later is supported - including all versions of Android TV (as long as the Play Store came pre-installed on that device).
If you need any help with installing the app, or have any questions about the BT Sport options, feel free to be more specific with your question.
