Message 1 of 4
Watch eurosport 1/2 on bt TV app
When I click eurosport 1 or 2 in the TV schedule view in bt TV app it says 'switch on bt TV box, channel 435/6'.  Is it not possible to use bt TV app to watch eurosport 1/2?  Note: my bt TV package allows me access to these channels through my bt TV box.
3 REPLIES 3
Message 2 of 4
Re: Watch eurosport 1/2 on bt TV app
Just worked it out: can watch via the Live bottom menu link
Message 3 of 4
435/436 are the HD versions of the channel, which is why it was telling you to watch on your box.
Channels 412 and 413 in the app (the SD versions) allow you to play them from the TV guide.
This is a good point though, that no-one has raised before. We may be able to make it more intelligent and recognise that they're both the same channel, and allow you to launch from either of the listings. I'll see if the data allows us to do this.  Thanks for raising it.
Message 4 of 4
The same thing applies to the BT Sport channels on the BTTV app. You can view the SD channels via the EPG but not the HD ones.
