Help us improve our customer experience. We are very keen to get your thoughts on some of the ideas we are exploring. Please take a few minutes to complete this short survey,
Hello.
I'm new to BT TV.
I don't appear to have BBC4 HD or SD.
Be grateful for advice.
Thank you.
I have found BBC4 SD, so you're telling me that I will not get it in HD via my BT box?
BBC4 is a broadcast channel via Freeview. The HD version is NOT available from relay transmitters. Your BT box also has multicast channels but these are NOT Freeview channels. So BBC4 HD is not an issue with BT but your local Freeview service.
@ChrisBwrote:BBC4 is a broadcast channel via Freeview. The HD version is NOT available from relay transmitters. Your BT box also has multicast channels but these are NOT Freeview channels. So BBC4 HD is not an issue with BT but your local Freeview service.
You might want to try the postcode checker function here to confirm what Freeview channels you should be receiving.
Thank you
There's a further check you could do via the BBC checker here.
This also confirms local transmitter options, current status and, if you select one, further confirmation of the broadcast channels.
If you are unable to receive BBC 4 HD Freeview you do have an option to use the BBC Iplayer available on your BT Tv/Youview box. If you have Select Prefered Video Quality set to Best Quality in your box BBC Iplayer Settings & Help section you should be able to watch BBC 4 programming at a quality level better than the SD Freeview Tv channel.
you can achieve this either by launching the iPlayer directly from the Appa section , from the backwards EPG guide or if you go to the SD channel and following the Hold Ok to restart in Player prompt.
Thank you but I am mostly frustrated by the fact that that I cannot record BBC4 HD because my particular genre is arts programming.
