ozsat
Expert
Message 1 of 6
BT Sport Box Office channel - press OK to setup
Often when a new channel is added you have to press OK to setup on the very first selection. The channel then opens (if available) after this.
But BT Sport Box Office channel on #494 does the press 'OK' to setup - but next time I go to it is says press 'OK' to setup again. This is repeating each time.
Is this what everybody is getting?
using Superfast Fibre 1 Unlimited with BT Max TV package (inc. UHD).
5 REPLIES 5
ney
Expert
Message 2 of 6
Re: BT Sport Box Office channel - press OK to setup
Yes im getting the same as you. Not that I will be using the BT Sport Box Office channel much if at all when the channel dose start.
Darren
Bluemoon1
Message 3 of 6
Don’t think I will be using it much either, first night fight at £16.95. (if you can stay awake all night may be worth it.)
ozsat
Expert
Message 4 of 6
Thank you for confirmation.
Guru
Message 5 of 6
I would hazard a guess that it will only be activated closer to the broadcasting schedule.
Stew
Bluemoon1
Message 6 of 6
If you go to BTSport Box Office on channel 494 now and press OK you have the option to BUY NOW or Cancel for the up coming fight night. Priced at as I mentioned before £16.95.
