Message 1 of 2
BT Sport HD
What is the bandwidth required for this on a YouView box?
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: BT Sport HD
Hi @PhilTaylor42
Welcome and thanks for your post!
For BT Sport HD on BT TV, a minimum speed of 5.25meg for existing and 6.5meg for new customers is needed.
Cheers,
Robbie
Community ModeratorRobbieMac
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
