scamartist
Message 11 of 19
Re: BT Sport and Powerline Adapters
@Roscotia
What Homehub do you have in your setup?
mgrowe
Message 12 of 19
I have a home hub 4 (Was a beta tester) and I am using powerline adaptors and get all of the channels OK including BT sports. Think it may be the luck of the draw.
roscotia
Message 13 of 19
I think its a Home Hub 3
mcgroa
Message 14 of 19
i was all set to bin my devolo 200AV PLA adapters and upgrade them since i was having issues and I read all about multi cast, IGMP etc.
Seesm the key is being on a Home Hub or other ADSL modem with a downstream chain that carries the multicast.  I have HH3 with port 1 going to PLA, and then PLA going to 4 way ethernet switch behind TV, and one cable from there to YouView box.
I had to take my Airport Extreme out of the loop as it doesnt work.
It now works fine on all the channels HD and SD.
scamartist
Message 15 of 19
Hopefully when I get my replacement Homehub 3 that will solve my problems.
roscotia
Message 16 of 19
My PLAs are 200 Mbps.  Would it make any difference if I upgraded to 500 Mbps ones?
scamartist
Message 17 of 19
it wont make any difference as the bandwidth they offer will never be used.
scamartist
Message 18 of 19
Homehub 3 arrived today.
Fitted it and everything worked first time using 200mb Devolo homeplugs..
Another sarcastic well done to BT for not checking if the router I already had from them was compatible with the service they are selling.
Homehub 2 dont waste time trying to get it to work.
roscotia
Message 19 of 19
Congratulations Scamartist!  You've given me fresh hope.  My Home Hub is a 3.  The PLAs I have been using were supplied by BT when I first got Vision years ago.  They are Simpler Networks 200Mbps.  Does anyone know if these are a good make?  They've been fine with the old silver box but the new black box seems to need a stronger signal.  Would it be worth my trying a better quality of PLA before giving up and going back to the old box?
