Tim25
Message 1 of 3
BT Store film rental
How long does a BT Film rental last for following payment? Presumably 48hrs if it’s like most other providers but why is this information so hard to find?? Instead there are phrases like “limited period” used in the guides.
2 REPLIES 2
zulu17
Distinguished Guru
Distinguished Guru
Message 2 of 3
Re: BT Store film rental
Hi @Tim25
it is 48 hours.
if within BT TV Player you  use the Help button on your remote or navigate to the help ?
You will get a  Help screen which has  a Buying, Renting or Upgrading  option which then has a further option All about buying or renting in the BT Player
That explains that “When renting you’ll have access for 48 hours..
Tim25
Message 3 of 3
Thanks very much for your help, although that info should really pop up when you make your rental purchase, not be hidden away.
