Message 1 of 62
BT-TV BOX PRO
Is it possible to have an aerial still connected and used while having the Internet mode selected on the latest BT-TV Pro boxes? Or is it one of those options only?
Haven't received the new box yet till next week.
Also if its only one choice only is there a preference recommendation?
I take it you can record any of the freeview channels that are streamed wirelessly with this box?
61 REPLIES 61
Message 2 of 62
Re: BT-TV BOX PRO
It's one or the other, choice is personal preference. IP gives more HD channels & HD channels on 1-5, but some channels missing & can only record two concurrent channels.
Message 3 of 62
Re: BT-TV BOX PRO
It depends on how much recording you do. In internet mode the maximum number of simultaneous recordings is 2, in aerial mode (if I remember correctly) it's 4.
This is explained in detail during the setup process
Message 4 of 62
Re: BT-TV BOX PRO
I take it 1-5 HD channels you refer to are BBC1 BBC2 ITV CH4 & CH5?
These channels I've quoted plus other available HD or SD available Freeview channels can be recorded via Internet mode too yeah?
Message 5 of 62
Re: BT-TV BOX PRO
Correct on both counts.
You might find this useful in your preparation BT TV Box Pro User Guide
Message 6 of 62
Re: BT-TV BOX PRO
As I currently have intermittent issues with the freeview channels via the connected aerial to the older BT-TV box I think my preference will be to use the Internet Mode only.
If you wanted to go back to using the aerial mode is it required to factory reset or anything?
Message 7 of 62
Re: BT-TV BOX PRO
Yes afraid so, factory reset required.
Message 8 of 62
Re: BT-TV BOX PRO
 in the guide it talks about recording 4 channels, I'd imagine it's referring to Aerial mode, so in theory you could record 4 simultaneously but you don't need to be watching the 4th, so does this sound correct, in the Non Internet Mode?
But in the Internet Mode you can record 3 programmes in total out of freeview and subscription channels by recording 3 simultaneously leaving the tv on one of those channels.
Does any of that sound right?
Message 9 of 62
Re: BT-TV BOX PRO
When I said don't need to be watching the 4th I meant leaving it on one of the 4 recording channels.
I'm confused though as I was informed by BT tech that it was record 3 watch 1 in aerial mode, and record 2 watch 1 in Internet Mode, is this similar to what I mentioned in my previous message?
Message 10 of 62
Re: BT-TV BOX PRO
Hmm, not sure but, as it says in the guide -
"You can speak to us on the phone too. Just call
0800 111 4567 anytime between 8am and 9pm. "
