magpie03
Expert
Message 1 of 7
Bt Sport Lite, Free?
I have BT Infinity & BT Mobile, should I receive Sport Lite for free or does it cost?
Tags (1)
6 REPLIES 6
Distinguished Guru
Distinguished Guru
Message 2 of 7
Re: Bt Sport Lite, Free?
I believe it is free but I suspect you need to order it (probably on the broadband side of your contract)
As it says in the BT tariff Guide
BT Mobile customers with BT Broadband should take BT Sport Pack on the BT Sport App & Online Player.
magpie03
Expert
Message 3 of 7
Right so I just need to place an order for it then, I'm currently switching from infinty 2 to 1 and it should be completed tomorrow so I will see if I can add sport then.
magpie03
Expert
Message 4 of 7
@zulu17
My broadband contract started yesterday and today I added bt sport lite and it said it was free which is fine. Will it be free for the full time Im in this current contract and did starting bt sport lite today start a new 12 month contract?
Distinguished Guru
Distinguished Guru
Message 5 of 7
As you know BT can and do change prices so no absolute guarantees .
I don't know about starting a minimum broadband term. That might depend on the precise method or offer that you signed upto.
Given that you only started your broadband contract with presumably a minimum term the day before if it might not mean much change.
Moderator
Moderator
Message 6 of 7
@magpie03 It wouldn't have started an new contract term on your broadband as it runs alongside the existing broadband contract that you recently agreed to.
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
magpie03
Expert
Message 7 of 7
@NeilO
Thanks I understand now as long as Im in contract bt sport lite will be free unless told otherwise!
Thanks again for the help 🙂
