pmuir79
Newbie
Message 1 of 3
Bt sport on vision + box & app
I have just recieved my bt vision + box and I'm waiting on my bt sport viewing card to come through the post. I was wondering if I can install the bt sport app on my iPad and use the app till my viewing card gets here. Basically I'm asking if you can use the app & bt sport on the tv at the same time or can you only use one or the other?
Reason I ask is cause I want to see the man utd v crystal palace game on Saturday.
Many thanks in advance for any advice.
2 REPLIES 2
FearlessFred
Message 2 of 3
Re: Bt sport on vision + box & app
There should be no problem with you installing the App on your iPad and running it. BT allows you to stream two different "channels" to two different tablets/phones/PCs/etc anyway (at the same time as watching on BTVision+ if you're so incluned!). All you will need is your BT ID and Password to log into the app, and you should be good to go.
pmuir79
Newbie
Message 3 of 3
many thanks for your help
