Bluemoon1
Message 1 of 2
CBS Player.
There is now a CBS Player on the players/apps page on Youview BT boxes .  Labelled CBS Catch up  and Horror Bites.
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: CBS Player.
Welcome back @Bluemoon1  and thanks for posting.
I hadn't noticed the CBS Player but will deffinitely check it out.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
