Message 1 of 6
Can I record Sky Sports Main Event on BT TV box?
I have the basic BT TV box which doesn't record  If I buy a BT TV+ box would I be able to record the Sky Sports Main Event chanel that I subscribe to
5 REPLIES 5
Guru
Message 2 of 6
Re: Can I record Sky Sports Main Event on BT TV box?
Yes. Why not consider upping your BT TV package which includes a recordable box?
Stew
Message 3 of 6
Thank for the reply StewM. What package would that involve? Can't I keep my existing package and just buy a new box?
Guru
Message 4 of 6
Yes, but it may work out cheaper to upgrade rather than buy a new one. Unless you get one from the famous auction sites. In any event I would ring the Options Team on 0800 800 030 and see what they can offer you.
Stew
Message 5 of 6
Unless there has been a change in the last year or so there is just one caveat, if you stop subscribing to sky you will not be able to view any of their recordings.
Message 6 of 6
I bought a BT Youview + box from EEEBUYGUM - I live in Yorkshire! It works a treat - I can even set it to record the Sky Main Event on the Youview app from anywhere.
Thank you to you for your help.
