Bridterry
Message 1 of 5
DISNEY TV
My son has subscribed to Disney TV which he can use to view on 4 devices at the same time. He has his own TV with an Xbox that he used to set up Disney for his TV. At times we watch stuff together as a family on the main TV which has a BT TV Box. It is an up-to-date version of the general box and not the all dancing video recording etc one. No icon has appeared in the Apps screen where BBC iPlayer, Netflix etc are.
Is it possible to add Disney to our Box or are BT restricting it so that we can only view by buying a package via them?
If possible instructions on how to do would be appreciated
4 REPLIES 4
stereohaven
Recognised Expert
Message 2 of 5
Re: DISNEY TV
Disney+ isn't currently available on a BT TV (YouView) box.
There are plenty of rumours around suggesting it will be added to the box in the future, but no precise date is available currently.
mmoukiou
Message 3 of 5
Re: DISNEY TV
Is your main tv a smart tv? If it's a recent model (around 2-3 years old), it's quite possible that there is a disney+ app for your tv that you can download.
Compatible TV devices:
Amazon Fire TV
Android TV
Apple TV
Chromecast
LG TVs
Roku tv
Samsung
Sky Q
Bridterry
Message 4 of 5
Re: DISNEY TV
Thanks for post. Whilst my TV is "Smart" it is around 5 years old now and the internet only works for pre-selected Apps. I rely on the BT TV Box for all the latest stuff.
Bridterry
Message 5 of 5
Re: DISNEY TV
A second thought which may be use is that if as you say Disney can be installed on an Android TV then using a separate Android box would presumably work.
