crush123
Message 1 of 5
Entertainment package - on demand
I currently have a now tv entertainment package which I can view on 6 devices.
it also allows me to watch a number of shows from previous seasons on demand.
does the BT entertainment package enable me to watch on demand shows ?
4 REPLIES 4
NigelB72
Recognised Expert
Message 2 of 5
Re: Entertainment package - on demand
By Entertainment package, do you mean the NowTV one or something else? If it's NowTV, you can watch via the NowTV app. Freeview channels are accessible by the apps for the individual networks if they have one.
NeilO
Moderator
Moderator
Message 3 of 5
Hi @crush123 yes you can still view the on-demand shows via the Now TV app on the BT TV box.
Cheers
Neil
crush123
Message 4 of 5
Thanks both, so getting entertainment package with BT essentially gives me a now tv  account with appropriate access
NeilO
Moderator
Moderator
Message 5 of 5
Good morning @crush123. Yes, you will get new login details for the Now TV app which can be set up on up to 6 devices and watched on 2 at the same time. The live-streamed Now TV channels can be viewed and recorded on the BT TV box through the TV guide.
Cheers
 Neil
