ivinsp
Message 1 of 5
GJ999 Error Code
Hi
I get a GJ999 error code, when I try to login into the TV App on my phone. Note 9
Tags (1)
Moderator
Moderator
Message 2 of 5
Re: GJ999 Error Code
Hi @ivinsp Sorry you are getting this error code when trying to access the BTTV App.
Please check out Problems logging into the BTTV App and online player.
If you are still getting this error code can you test on another device to see if you get the same err?
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
ivinsp
Message 3 of 5
Hi John, I've tried on another device, android and get the same error. Paul
Moderator
Moderator
Message 4 of 5
Hi @ivinsp thanks for trying that for me. Please send us over your details by clicking on my profile and selecting the contact the mods option and we will work on getting this fixed for you.
Cheers
John
Kudos”
ivinsp
Message 5 of 5
Ok, A Rightnow case has been raised# Edited by Mod
