chilton55555
Message 1 of 5
HDR
I have a new LG OLED E9, does the BT TV Ultra box support HDMI Ultra HD deep color?  I have it switched on at present should I leave it on or switch it off?
4 REPLIES 4
ozsat
Expert
Message 2 of 5
Re: HDR
BT currently do NOT have a set-top-box that does HDR - so not point in setting the tv up top accept it - but if you've done it then I guess no point in undoing it either.
using Superfast Fibre 2 Unlimited with BT Max 4K package.
chilton55555
Message 3 of 5
Re: HDR
Hi many thanks for the response as long as it will not negatively impact on picture quality I will just leave it enabled.
chilton55555
Message 4 of 5
Re: HDR
I have a 4K firestick which supports HDR, will that work OK using BT TV app?
ozsat
Expert
Message 5 of 5
Re: HDR
Nope - but hopefully BT will add support for this too.
