Message 1 of 3
Internet mode
Hi.  My BT TV Pro box is currently configured to receive Freeserve channels via the aerial.  I want to change the box to internet mode but can’t find the relevant section in setting to change the mode. Can anyone shed any light please?
2 REPLIES 2
Message 2 of 3
Re: Internet mode
It's not as easy as that.
First unplug the aerial from the box then factory reset it.
Once set up, you may need to do a manual update from the settings menu in order to populate the EPG
Message 3 of 3
Re: Internet mode
Much obliged to you Les.
