Message 1 of 3
Live football on BT
Hi folks,
New to this so hopefully this is the right place to post! I'm looking for something that should be quite basic, but I can't find it anywhere!
Basically, I want to find a list of every Premier League and Championship match that was shown live on BT during the 2018/19 season, and so far in the 19/20 season
Can anyone point me in the right direction??
Many thanks
2 REPLIES 2
Expert
Message 2 of 3
Re: Live football on BT
Zero Championship directly from BT Sport .... Sky are the rights holders .... So you'll need to check what matches from the Championship got shown on Sky Sports Main Event and therefore made available via an add on on BTTV.
Premier League .... Easy but will require some leg work from you ....
The Premier League website results lists show the broadcaster which covered the match
2018/9 season here ....
https://www.premierleague.com/results?co=1&se=210&cl=-1
Message 3 of 3
Thanks Chris, I found the premier league link shortly after posting on here, which as you said, did require a bit of leg work but I found what I was looking for.
Thanks again
Steve
