Someone been fiddling with it? And can't reset it to record! 😞
Solved! Go to Solution.
FP3 is also missing from mine, I've set them to record as one offs rather than a mini series, the option was there for both.
Reboot didn't help. With trepidation I then deleted the series link completely concerned it would then not allow me to set a recording for any of the sessions and races but then I reset it and all is now as it should be and I can take my usual break between FP3 and quali to go for a run or a walk (which it is depending on the state of the weather and of my asthma).
