GG1
Message 1 of 8
Netflix Activation Email
I have changed my tv package and chose Netflix as an add on. I have received my new bt tv box and it is all set up and working nicely. I was advised on my order confirmation email from bt that I would receive a separate email to set up Netflix, this has not arrived and the status of my order on my bt is order complete - but no mention of Netflix?
Can someone pls look at my account/order and advise what to do next?
Thank you.
7 REPLIES 7
PaddyB
Moderator
Moderator
Message 2 of 8
Re: Netflix Activation Email
Hi @GG1,
Welcome to the Community and thank you for posting. If you haven't received the activation email for Netflix, you should still be able to complete the activation if you sign into the link www.bt.com/bttv/netflix with your BT ID.
Please give that a try and let me know how you get on?
PaddyB
Ashmcc
Message 3 of 8
Hi I am in the same situation no email activation link and when i use the bt netflix activation link you give nothing happens (it says it should open a new window) any ideas?
GG1
Message 4 of 8
Hi PaddyB thank you for your reply. I have tried your suggestion and like Ashmcc no window opens when I click on Get Started?
PaddyB
Moderator
Moderator
Message 5 of 8
Hi @GG1, and Ashmcc,
Thank you for posting back I'm sorry if that hasn't worked. What internet browser are you using and if it's possible can you try a different one?
PaddyB
Ashmcc
Message 6 of 8
Im using safari - will try now on explorer.
GG1
Message 7 of 8
Hi PaddyB,
I was using Safari too - I have switched browser and I'm pleased to say that worked and I am now set up 🙂
Thank you!
PaddyB
Moderator
Moderator
Message 8 of 8
Hi @GG1,
That's great thank you for posting back.
Cheers
PaddyB
