Message 1 of 5
Newby to BT TV / BT Sport
Hi - have just received BT TV Box - so bit confused - do I find the 'Live Sport' from the blue BT Services button - or are the 'Live matches' shown in the Guide (by pressing the guide button - then Blue button to filter 'subscritions') - as previously used laptop & was easy to see live matches - Or do I just goto channels 408-411 for my BT sport subcriptions? -Thanks
4 REPLIES 4
Guru
Message 2 of 5
Re: Newby to BT TV / BT Sport
Hi, you use the EPG which will include the channel numbers to view what’s on your live channels and to chose the channels you want.
The blue Youview button is used to view your recordings in MyTV or the settings of the box.
The BT Player button is to view VOD (video on demand) and films, music depending on your subscription.
Stew
Message 3 of 5
Thank you. I see now.
Moderator
Moderator
Message 4 of 5
Stew
Nice one @StewM Smiley Happy
Message 5 of 5
Hi - Thanks - at first is very confusing - As you sort of expect to see your subscriptions by pressing the 'blue' BT services button - it was not obvious that actually the 'subscription' channels are listed in the guide, starting 408 - Anyways, got there now 🙂 - Thanks
