Message 1 of 14
Now TV channels on EPG
I have Now TV entertainment package with BT TV but the Now Sky channels not showing in EPG. Software up to date, please advise - seems like a common problem. Thank you
13 REPLIES 13
Message 2 of 14
Re: Now TV channels on EPG
Same problem following my recent BT TV activation. My order is complete, but I also cannot access TV -> TV Guide section as it is reporting my ID isn't activated but it is. I believe this is due to an historic account My Services are all greyed out. Previously attempted to resolve this via Chat support is no success.
I can load the Now TV app and find the missing linear channels but it does leave them rather hidden away and not obvious whats currently airing.
Message 3 of 14
Hi @Smithwade45 and @Starman I'm sorry the Now channels are not appearing in your EPG. Please can you try a factory reset of your BT TV box ensuring to choose the option to keep your recordings and let me know if that helps?
Neil
Message 4 of 14
@NeilO already tried that after 24hrs no change.
Message 5 of 14
@NeilO  @Starman
I had the same issue and a factory reset alone did not fix it.
First I had to go into settings / software info and do a software update then do a factory reset then it worked.
I thought this quite strange as the box did a software update as part of the installation procedure so when I tried the manual update, I expected it to report that I already had the latest software but it didn't but strange or not it sorted the problem
Please help the community to help you by including all relevant information, single word responses may be quick to type but they offer little value to this Community Forum and do not help its team of volunteer members to help you.
Message 6 of 14
Thanks Les I've tried that (check software/apps update) it's reports up to date but reviewing Youview page suggest it's stuck on software from September can't remember the exact version number currently as out and about. Was the EPG addition a new feature?
Message 7 of 14
As far as I know it's the same EPG that's been around for a while, @DarrenW is the man in the know.
Message 8 of 14
Hi, @Starman I'll send you a private message so you can get in touch with the moderation team and we'll be happy to get that looked into.
Neil
Message 9 of 14
Thanks for this reply. Unfortunately, I did the factory reset and it’s still the same. I saw that some people have fixed the issue by being pushed a manual  software update, but let me know if any other suggestions. Thank you
Message 10 of 14
Hi @Smithwade45, thanks for the update and sorry it hasn't fixed things for you.
I've sent you a Private Message so you can get in touch with the Mod team and we'll be happy to help you with this.
Cheers
John
