Message 1 of 8
Re: BT Pro box not showing BT Sport 4k (ch433)
I have the exact same problem . Old 4K box works fine. New pro box does not show 433. Black screen. I’ve have new pro box sent. They’ve even renewed my contract. Crazy.
move had I think 10+ calls now with BT.
Can someone help please?
thank you.
7 REPLIES 7
Message 2 of 8
Hi @Wreptile and welcome back. It's been a while.
I'm assuming you've been through the factory reset procedure etc already so I'll drop you a private message now so you can get in touch.
Cheers
David
Message 3 of 8
Hi there.
Yea done all the resets. And had amother pro box sent too. No change.
thanks
Message 4 of 8
Are  you using an amp out of interest?
Message 5 of 8
I am using a sound bar that is connected to HDMI #4 on my TV. No amp direct connection to the pro box
Message 6 of 8
Ah ok sorry I can’t help then in that case. My issue turned out to be that my Yamaha RX-V1073 doesn't have HDMI 2.0 or HDCP 2.2 so won't pass through true 4K it would pass through a basic 4K/30 signal. This seemed to mean that the 4K channel would show fine from the old box but not on the new bt pro box so I assumed they have different 4K specs ? I got around it by plugging the bt pro box straight into the tv. Obviously you are already doing this
Message 7 of 8
 thanks for the suggestion. It’s an odd one.
Message 8 of 8
Thanks for taking my call today @Wreptile .
I can appreciate how frustrating this has been for you but I'm glad the engineer was able to get this sorted or you eventually. Please get in touch if you have any other problems.
Cheers
David
