Jonboi
Message 1 of 13
Recording unavailable
Hi, I recently recorded the repeats of Ever Decreasing Circles from GOLD, I tried to play one but get message - recording unavailable IPC6035, I have reset the box & router to no availe, other episodes seem to be OK just this one, any suggestions please.
Message 2 of 13
Re: Recording unavailable
Welcome to this user forum.
Perhaps the content has expired or been removed by the content provider?
Jonboi
Message 3 of 13
Seems a bit strange as they were only recorded a couple of months ago, there are 18 in the series but only only one has this error...
Message 4 of 13
Perhaps that one did not record properly?
Jonboi
Message 5 of 13
Maybe, but there is no error or failed recording message..
Message 6 of 13
In that case, it must have been removed by the content provider. This can happen if a particular episode had a time limit on it for some reason.
The BBC often do that on the iPlayer service. You can get episodes of a series, and one will only be shown once, while the rest will remain.
For example, tthe BBC did a series about the National Grid, a few years ago. But the final episode "pulling the plug" was removed from the iPlayer content, shortly afterwards, but the rest of the series remained. I think it was too political Smiley Wink
Jonboi
Message 7 of 13
OK Thanks Keith, This was the episode about a farmer who stopped Howard & Hilda using a public footpath, it will probably be on again soon as they are repeated every few months...
Distinguished Guru
Distinguished Guru
Message 8 of 13
Recordings if successfully completed are on your YouView hard drive , upon play back of recordings off a BT subscription channel  a check would be made for a current subscription to that channel.
That is a different to catch-up or on demand or rented  or bought programmes selected off a Youview player which typically will have date and time availability  restrictions at individual programme episode level.
Jonboi
Message 9 of 13
As I said  there is just a problem with one episode, I record quite a few things & nothing else has been affected, I have been a BT subscriber for a long time....
BT TV Expert
BT TV Expert
Message 10 of 13
Hi,
Is the recording that is failing to playback with an IPC6035 error a recording from October 23?
Gavin
BT TV ExpertGavinL
Show your appreciation!
Click on the thumbs up next to a reply to say thanks
Kudos”
I am a BT Employee and an expert on TV queries. I am here volunteering my own time to give advice, and help where I can with BTTV queries. Go here for more info.
