Madangler
Message 1 of 3
Supercup sound issues
Picture is Ok but sound is dreadful. Am I the only one who's had to mute the sound?
Sorted, up and down to different channels, sound now good.  Should have done that before posting.
2 REPLIES 2
Moderator
Moderator
Message 2 of 3
Re: Supercup sound issues
Hi @Madangler,
It's good to see you back on the Community and thank you for posting.
I'm sorry you were experiencing sound issues during the Supercap. I had the same problem myself and changing the channel for a moment cured the issue, not ideal I know.
If you're still having problems with your sound this might help -Sound problems on BT TV
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”Kudos”
gomezz
Recognised Expert
Message 3 of 3
I occasionally find that my ancient Denon AV amp does not always change mode correctly from DD to ProLogic etc when changing channel or watching a recording. At which point I manually cycle through the available audio modes on the amp round back to Auto and it usually then gets its right. Unless there is an actually issue with the broadcast audio which sometimes means forcing the amp to use the analogue audio feed coming via my TV rather the digital feed coming direct via optical to the amp.
