Bluemoon1
Message 1 of 5
The Terror on BT Player
Anyone else tried watching TheTerror on bt player. I have watched episode one but episode two only plays for ten minutes and stops. When i go back to the tile page it states “30 mins left continue watching “ but it will not play the rest.
4 REPLIES 4
Trace-T
Message 2 of 5
Re: The Terror on BT Player
Same here, though it plays in full if you switch to SD mode.
Bluemoon1
Message 3 of 5
Haven’t tried SD but it plays via bt tv on my iPad and it continues from  where it stops on the bt player.
scointer
Recognised Expert
Message 4 of 5
Episode 2 of the terror on the bt player is short
When I start watching episode 2 of th terror on the BT player it is only 9 minutes long even though it says it is 40 in the description.
Moderator
Moderator
Message 5 of 5
Re: Episode 2 of the terror on the bt player is short
Hi All, Thank you for highlighting this issue.
I can confirm that following an investigation the issue was identified, and following testing, I can confirm that the issue should now be resolved. Please check and post back if you are still having any issues watching this.
Cheers
John
