nubia
Newbie
Message 1 of 7
bt not fixing problems
3 months ive been on to them to get my hd channels and the bt 4k sport working and still nothing then they go and try to charge me a extra £6.50 a month to get them turned on and i dont know what to do since they dont seem to be doing anything to fix it at all
6 REPLIES 6
-Richie-
Expert
Message 2 of 7
Re: bt not fixing problems
What BTTV package do you have ?
£6.50 is the monthly cost of the HD Addon, you don't get 4K unless you're on the top package, which is Max 4K, the Max 4K package includes the HD Addon at no extra cost.
nubia
Newbie
Message 3 of 7
TV
Max 4K Sport 4K
Over 55 Premium entertainment channels including 23 in HD
BT Sport in 4K Ultra HD
Watch BT TV wherever you are with the BT TV App Extra
Up to 94 Freeview channels including up to 16 in HD
like that you mean
Moderator
Moderator
Message 4 of 7
Hi @nubia,
Welcome to the Community and thank you for posting. I'm sorry you haven't been able to watch the HD and 4k BT Sports channels included in your package.
If you're on the BT TV Max 4K Sport package, then you are right in that these channels should be available as part of your package. If you send me in your details, I'll be able to get this sorted.
I have sent you a private message with instructions on how to contact me. You can access your messages via the envelope icon at the top right of the screen, or click on this link, Private messages
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”Kudos”
nubia
Newbie
Message 5 of 7
i cant seem to send any pms xD
Moderator
Moderator
Message 6 of 7
Hi @nubia  sorry that you did not receive a PM from Paddy and for the delay in getting back to you. I've sent you a Private message explaining how you can contact the forum moderation team.
Check here: https://community.bt.com/t5/notes/privatenotespage
thanks
John
Community ModeratorJohnC
Kudos”Kudos”
Moderator
Moderator
Message 7 of 7
Hi @nubia  thanks for your PM to confirm that you have already got this resolved and sorry it took a lot longer than it should have to correct things for you.
cheers
John
Kudos”Kudos”
