paul1955
Message 1 of 9
bt sport
Hi,
I have registered for Bt sport using my daughters laptop however when i now try to log in on mine its seems to load but does not get to screen showing picture, is this because you can only watch it on the laptop it was registered with?????
Kind Regards
8 REPLIES 8
tvwatcher
Message 2 of 9
Re: bt sport
You are able to stream on 2 concurrent devices at any one time
paul1955
Message 3 of 9
Re: bt sport
any ideas as to why it wont seem to load screen then????
tvwatcher
Message 4 of 9
Re: bt sport
what device are you on IOS or andriod?
paul1955
Message 5 of 9
Re: bt sport
it is a laptop so IOS i suppose????
tvwatcher
Message 6 of 9
Re: bt sport
ok did it ever work on your laptop? as the first question would if you have the right hardware to run it. Is the laptop an apple one? or running windows?
paul1955
Message 7 of 9
Re: bt sport
never tried it as got my daughter to set it up initialy its running on windows
tvwatcher
Message 8 of 9
Re: bt sport
sounds odd, I would suggest emptying the cache on your laptop, ie internet explorer. then log back into mybt and try and cliick on watch now and see if this works
check on the top of the screen in case it asks you to install anything, as if you have pop up blocked this may be the problem, ie the site needs somethign installed and you cant see this - just an idea may well be wrong
Distinguished Guru
Message 9 of 9
Re: bt sport
If it's a PC - Windows or Mac - it needs Microsoft Silverlight installed to play the video.
See http://www.microsoft.com/getsilverlight/Get-Started/Install/Default.aspx
If it's installed, but you're not sure it's working, try http://support.akamai.com/silverlight/ (and click on the Play button).
If you're getting obscure error messages, see if it's covered here: http://bt.custhelp.com/app/answers/detail/a_id/45987/~/bt-sport-app-and-online-player-error-messages
