bigsacko
Newbie
Message 1 of 4
i want to cancel my sky sports package
i want to cancel my sky sports package which i have on my BT TV i tried phoning the BT customer helpline but the said *Edited by Mod* they are unable to help. anybody have any information on what i can do
3 REPLIES 3
Guru
Message 2 of 4
Re: i want to cancel my sky sports package
Hi, can't you cancel through MY BT. If you go to add add-ons it will summarise all your add-ons allowing you to cancel anyone of them.
Stew
Moderator
Moderator
Message 3 of 4
Hi @bigsacko I've dropped you a Private Message. Please check it for further information.
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Guru
Message 4 of 4
After the edit, my response is wasted.
Stew
