Message 1 of 8
HD EXTRA ADD ON
Is there any requirement for the HD EXTRA addon for those with the BT-TV BOX PRO?
I ask as most that were available on HD EXTRA addon have gone from BT-TV such as DAVE HD, and the ones that are available from the list are 2 eurosport channels which are available on the BTSPORT HD which I have already, and a couple of other channels that have a different channel number.
So it seems there's no requirement for the HDEXTRA ADDON, is this correct?
Tags (2)
7 REPLIES 7
Message 2 of 8
Re: HD EXTRA ADD ON
The FTA (Freeview) channels have HD variants with more available via IP terrestrial delivery. If you have the HD add on for BT Sport, you'll get those in HD but if you have the Sky/NowTV channels, these aren't HD unless you add the NowTV HD Boost. This will allow access to the HD NowTV channels which are in 1080p
Message 3 of 8
Re: HD EXTRA ADD ON
@NigelB72
Here is what it says on the online account:
4K Ultra HD Add on
AMC Channel and On Demand
BoxNation
BT TV App Extra
Channel Pack 3
Large screen
Current add ons
NOW Entertainment Membership
NOW Boost
Message 4 of 8
Re: HD EXTRA ADD ON
Is channel 390 and 391 Sony TV available as a separate addon?
Message 5 of 8
Re: HD EXTRA ADD ON
Those two channels (390/391)  are part of the Asian Mix add on
https://www.bt.com/tv/on-demand/asian-mix-tv-channels-whats-on-guide-zee-tv
Message 6 of 8
Re: HD EXTRA ADD ON
@zulu17
So should I have these going by what I mentioned what it says on my online account?
Message 7 of 8
Re: HD EXTRA ADD ON
No you would need to order  the Asian Mix addon.
Message 8 of 8
Re: HD EXTRA ADD ON
Thanks, I just wanted to check I wasn't missing anything.
