Message 1 of 3
Interference/Channels Breaking up
Starting this week I noticed that sports channels (e.g. TNT Sports, Eurosport) have some kind of interference and the image and sounds are constantly breaking up. I have had this setup (i.e. box, powerline, router) for over 3 years without any problems.
No problem with internet speed. Already factory reset the box, but it continues with the same problems.
Any idea?
2 REPLIES 2
Message 2 of 3
Re: Interference/Channels Breaking up
Are you able to temporarily try with a cable connection rather than via the power line adapters ?
Message 3 of 3
Well, as I mentioned I restarted the BT box and the router without success but after restarting the hub (i.e. the box that receives the signal from outside of my house and connects to the power line and router) it seems it solved the problem.
