Anonymous
Not applicable
Message 11 of 13
Re: Sky Sports UHD
@imjollywrote:
I have BT sport on SKY but you need to pay BT for HD  even if you have SKY HD/UHD as the sky addition only covers SKY channels
That isn't correct.
BT Sport in HD is included as standard if you buy it via Sky and always has been, you only pay extra for HD if you are paying BT for access to it on Sky.
If you buy BT Sport via Sky you get access to the normal 4 channels in HD, plus the 'Extra' channels via red button, plus the channels on any multiroom boxes and via Sky Go.
With BT you get access to the BT Sport app, then the charge is for SD on Sky on one main box, then extra for HD, then extra for each multiroom box, which is significantly more expensive unless they offer you a discount as a BT Broadband customer.
Message 12 of 13
Re: Sky Sports UHD
@Anonymous
that may well be the case but it is not if you get BTSPORT from BT and view on SKY.  you need to upgrade your BTSPORT with BT to HD to be able to watch in HD on SKY even though you may have SKY HD/UHD
Anonymous
Not applicable
Message 13 of 13
Re: Sky Sports UHD
Apologies, I read your reply as you have BT Sport via Sky put pay BT for HD.
