Message 1 of 8
Viaplay
How do I watch Viaplay Sport on BT?
7 REPLIES 7
Message 2 of 8
Re: Viaplay
It is not available on the BTtv box - you would need to subscribe to their online service which will allow you to use their app on other devices.
Message 3 of 8
Re: Viaplay
Thanks. Further confirmation I made a mistake switching from Sky.
Message 4 of 8
Re: Viaplay
Viaplay Sport is available as an extra subscription on an existing Prime Video subscription. So the Prime Video app on the BT TV Box could be used to view if you had the relevant subscriptions.
Message 5 of 8
Re: Viaplay
Or use a Chromecast of Firestick dongle to give you a much wider access to the many and varied online streaming services which are not able or willing to cut a deal with the major TV service providers.
Message 6 of 8
Re: Viaplay
Yes I have a fire stick but that still means subscribing to Amazon AND Viaplay.  Simply not worth the hassle.
Message 7 of 8
Re: Viaplay
You're better off using the ViaPlay app if you have a firestick. It's the best way to do it as you can stream everything and get catch-up up to 48 hours after the event. Watching through Prime Video only gives you the channels as far as I'm aware.
Message 8 of 8
Re: Viaplay
You'll also get all the extra streams not available on Sky boxes.
