den_chr
Newbie
Message 1 of 4
Accessing webinterface on Yale Smart Living Hub (port 80)
Good evening,
I've recently bought two Yale Doorman lock-systems for my house (like these: https://www.yale.dk/da/yale/dk/produkter/yale-elektroniske-lase/yale-doorman/yale-doorman-mpl-komple...) . I've installed two matching Yale-modules to communicate with my Yale Smart Living Hub (like this one: https://www.yale.dk/da/yale/dk/produkter/yale-smart-living-/yale-smart-living-hub/ ) .
It's all working perfectly fine and communicating with the corresponding App "Yale Home".
The Smart Living Hub are connected to my router to provide acces to the internet - and off course the hub is equipped with an IP assigned by the build in DHCP-server in my router.
Now to the question; when accessing the assigned IP-address of the hub in a webbrowser (e.g. http://192.168.1.8/) on port 80 I'm met with a prompt asking for a username and password.
I have absolutely no idea what the user and password might be and I can't seem to find anything in the documentation for the hub about the web-interface. If the prompt about the user and password is closed I'm met with several choices in a horizontal menu-system (typical web-layout). See the screenshot in the bottom of the post.
I'm very curious about the web-interface and how to access it. Does anyone in the forum know which credentials to use?
Thank you in advance!
Best regards,
Christian, Denmark
Screenshot, Yale Hub webinterface:
3 REPLIES 3
Message 2 of 4
Re: Accessing webinterface on Yale Smart Living Hub (port 80)
This is a UK BT retail forum and has absolutely no relevance to your question. I suggest you post on a Yale forum.
Message 3 of 4
Hi
I got exactly the same problem, accessing the Yale connect hub!! I'm looking for the same problem
Message 4 of 4
The advice is the same - try the Yale  forum
