astar27
Expert
Message 1 of 2
BT ADSL Checker
Look at the new type of results when you tap in the number into the checker http://www.dslchecker.bt.com/adsl/ADSLChecker.TelephoneNumberOutput , it tells you your cab number now.
1 REPLY 1
Distinguished Guru
Message 2 of 2
Re: BT ADSL Checker
So it does and lots of clear info
BTLife | 1967 Plus Radio | 1000 Classical Hits
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Helpful Post?
If a post has been helpful, say thanks by clicking the ratings star.
