Message 1 of 7
BT Forum and Firefox
Does anybody have problems posting answers via firefox ? My cpu and memory max out yet edge is fine?
6 REPLIES 6
Message 2 of 7
Re: BT Forum and Firefox
Posting this using Firefox 129.0 (64-bit) on MacOS with no problems.
Message 3 of 7
Posted on Firefox 129 using Windows 11 Pro...no problems.
Message 4 of 7
Quick reply has no problems. Normal reply option connecting to bt.com etc is forever displayed page hangs. I disabled every addon no effect.
Message 5 of 7
It was normal reply, as you put it, that I used.
Message 6 of 7
As per @WSH 'normal reply' is also fine for me.
You can use F12 to open a developer/debug pane in Firefox and potentially use that to see which part of the page is hanging, but you'll probably need to search for a tutorial if you're not fanmiliar with their use.
Message 7 of 7
I found this topic whilst searching for others who had issues with Firefox. I'm writing this using normal reply and it seems to be working. I'll preview it and then post it so if you are reading it then I guess it worked.
I found this topic whilst searching for problems using Firefox for this forum. The problem I'm having is that I can't find my older private messages - https://community.bt.com/t5/The-Lounge/BT-Forum-Firefox-private-messages/td-p/2418649
I think all the other posters are Firefox users so I would appreciate any advice from them but I don't mean to hijack this post.
