cra1gst
Message 1 of 7
BT Home smartphone S Boot LOOP
My land line is stuck in a boot loop but i can get in recovery mode same way as most andriod devices
is there and rom i can download to fix my issue ?
thanks craig
Tags (1)
6 REPLIES 6
Message 2 of 7
Re: BT Home smartphone S Boot LOOP
Try the help page http://bt.custhelp.com/app/answers/detail/a_id/44950/~/bt-home-smartphone
Its an obsolete product now.
cra1gst
Message 3 of 7
yea i did check that first , i know but dont wana have to buy new land line every few years
Message 4 of 7
A normal cordless phone lasts many years, and does not normally go wrong. I don`t think the BT Home Smartphone was a commercial success.
cra1gst
Message 5 of 7
yea i see why 2 bugs always need to restart ,  but if i get the rom can fix mine , my 2 phone lines are in the loft so not best , going to hook em to voip system if cant fix it
Message 6 of 7
I would imagine by now, that the internal battery would need replacing, unless you have already done that. A worn out battery with a low capacity would upset most Android phones.
As this is not a BT landline fault, I will move this thread to the lounge board. You may get some other suggestions.
cra1gst
Message 7 of 7
Great thank you , and didnt think of that but is possible boot loop dont last on battery only plugged in
