Message 1 of 7
BT Pavement plate
Who deals with issues surrounding the BT pavement plates that have the cables underneath with regards to water pooling around the BT pavement plate?
6 REPLIES 6
Message 2 of 7
Re: BT Pavement plate
Openreach own the manholes, its nothing to do with BT Retail.
If its a problem with the footpath not being level, then your local council.
Message 3 of 7
Thanks, I've reported it to the local council.
Message 4 of 7
It's not about it being level, it's more about it not having the proper drainage on the surrounding area.
Message 5 of 7
Good luck with that one.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 6 of 7
The bad thing is when water spouts up.  Worse still when it contains sewage.
Message 7 of 7
Thanks for the help.
