CooperJM
Newbie
Message 1 of 3
BT Phone Box
Hi
In our village there used to be a phone box that has recently been removed, we believe that this was done illegally and not by BT. How can we find out if BT did remove/authorise the removal of the phone box?
Jason
2 REPLIES 2
Message 2 of 3
Re: BT Phone Box
Moderator
Moderator
Message 3 of 3
Re: BT Phone Box
@CooperJM Hi Jason, if you give this number a call tomorrow on 0800 661 610 they'll be able help. They can assist with payphone faults and enquires and open 8:30am to 5pm Mon-Fri.
Community ModeratorNeilO
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
