Message 1 of 9
BT manhole
I need to find out whether a BT concrete covered inspection chamber in the ground can be relocated as is near to a wall that needs to be rebuilt. Please advise. Tony
Tags (1)
8 REPLIES 8
Message 2 of 9
Re: BT manhole
Tags (1)
Message 3 of 9
Re: BT manhole
Thank you 👍
Tags (1)
Message 4 of 9
Re: BT manhole
Just to make you aware it's not going to be cheap.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Tags (1)
Message 5 of 9
Re: BT manhole
What's the cost of resetting the chamber lid if I want to add dropped kerbs ?
Tags (1)
Message 6 of 9
Re: BT manhole
As per message 2.
Tags (1)
Message 7 of 9
Re: BT manhole
Depends on what type of Joint Box it is. If it’s a JMF then it’ll need to be rebuilt as a JBF so it can support the weight of a car driving over it.
Tags (1)
Message 8 of 9
Re: BT manhole
Got quote from openreach. Cost to rebuild the chamber £4500. Concrete chamber will needed to be rebuild even if only the lid level needs changing.
Tags (1)
Message 9 of 9
Re: BT manhole
Up to you to contact openreach and decide if you are proceeding with the chamber rebuild
Tags (1)
