Message 1 of 4
Broadband connection
We are on a copper connection to a cabinet some 300M away where, I think, fibre ends. Our speed averages 29Mbps. Our current ISP, vodafone, gives a 15% discount for not meeting the package minimum speed (63Mbps Superfast 2).
If we switch to BT could they improve the speed?
3 REPLIES 3
Message 2 of 4
Re: Broadband connection
As the connection will use exactly the same connection from the cab to your home it is unlikely there would be much difference if any in connection speed
enter your address and delete before posting
Message 3 of 4
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream HandbackThreshold(Mbps) WBC FTTC Availability Date WBC SOGEA Availability Date Left in JumperHigh Low High Low        VDSL Range A (Clean)
VDSL Range B (Impacted)
52.23510.2731.9AvailableAvailable--
50.532.4106.525AvailableAvailable--
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Range (Mbps) Availability Date FTTP Install ProcessFTTP on Demand
33030--Available--
ADSL Products Downstream Line Rate (Mbps) Upstream Line Rate (Mbps) Downstream Range(Mbps) ADSL Availability Date WBC SOADSL Availability Date Left in JumperWBC ADSL 2+WBC ADSL2+ Annex MADSL MaxWBC Fixed RateFixed Rate
Up to 6.5--5.5 to 7.5AvailableAvailable--
Up to 6.5Up to 15.5 to 7.5AvailableAvailable--
Up to 5.5--4.5 to 8AvailableAvailable--
2----AvailableAvailable--
2----Available----
Observed Speeds VDSLMax Observed Downstream SpeedMax Observed Upstream SpeedObserved Date
29.99
6.84
2020-12-11
Other Offerings Availability DateVDSL MulticastADSL Multicast
Available
Available
Premise Environment StatusBridge TapVRINTE FacePlateLast Test Date
U
N
N
24-12-2020
Exchange Product Restrictions StatusFTTP Priority ExchangeWLR WithdrawalSOADSL Restriction
N
N
Y
The premise/line is associated with exchange which is NOT part of current fibre priority programme.
The premise/line is associated with exchange where WLR is not withdrawn.
The premise/line is associated with exchange where SOADSL service is restricted.
FTTP is not available.
For all ADSL and WBC Fibre to the Cabinet (VDSL or G.fast) services, the stable line rate will be determined during the first 10 days of service usage.
Actual speeds experienced by end users and quoted by CPs will be lower due to a number of factors within and external to BT's network, Communication Providers' networks and within customer premises.
The Stop Sale date for IPstream is from 31 Oct 2012. The Formal Retirement date for IPstream is from 30 Jun 2014.
If you decide to place an order for a WBC fibre product, an appointment may be required for an engineer to visit the end user's premises to supply the service
In order to be eligible for handback, downstream speed should be less than Downstream Handback Threshold values.
Thank you for your interest
Message 4 of 4
Looking a thing dslchecker results your estimated speed range is 52/35mb so having fibre 2  or vodaphone equivalent you will never get anywhere near 63mb connection speed
