Newbie
Message 1 of 9
Broadband to my house
I have a fibre optic cable running past my house and understand that my neighbour has super fast broadband.  When I type in my post code it says I'm only eligible for slow broadband but when I type in his post code he is eligible for super fast.  Why can't have I super fast broadband when it's on the telephone pole opposite my house?
8 REPLIES 8
Message 2 of 9
Re: Broadband to my house
do you currently have broadband with another ISP not BT?
Message 3 of 9
Post codes are the least accurate way of checking for broadband.
If you have a BT phone use that number to check or second best, use your address.
Recognised Expert
Message 4 of 9
Hi @jjd1 ,
Is it a nextdoor neighbour, as it is pretty unusual to have different postcodes ?
In any case, as others have posted, a number check is best followed by the address.
Message 5 of 9
The street I live in has a different post codes for even numbers so this could take it into a different area for the postcode check to see what types of broadband are available. As stated, the post code check should be the last one to use and even then do not depend on the result as being anything like accurate.
Newbie
Message 6 of 9
Yes, we currently have Sky broadband with a download speed of 10 and upload 0.04
Newbie
Message 7 of 9
Thanks for the advice, will do..
Newbie
Message 8 of 9
Our neighbour is at the bottom of the hill and we're at the top. Only three properties have our postcode.
Newbie
Message 9 of 9
Thanks for your advice...
