intrest5544
Message 1 of 3
Buzz on background of tone
Hello,
I bought a BT phone.
I am using it in Estonia, not UK.
When I pick up the handset, there is tone but it has a buzz on the background.
Phone is connected to a box and then cable from the box is connected to the Phone company's provider modem I guess.
So if I touch either of 2 lower contacts (blue or blue/white) with my finger, the buzzing noise goes away. My body is like a resistor or something. Contacts are screwed together fine, no prob with that.
How do I make the buzzing noise go away?
Regards,
K.
2 REPLIES 2
Message 2 of 3
Re: Buzz on background of tone
This is a BT UK Retail forum for customers of BT Retail.
You will need to contact your own local phone provider.
intrest5544
Message 3 of 3
They are not very competent. They say all is fine on their side. It's cheaper to buy a new phone than call the phone mechanic guy.
