Chapate1
Message 1 of 6
By phone line ext
Hi quick bit of advice, bt box phone connection, can I run an ext from this externally and back in through the wall so I can move my tv to other side of room without having cables running along the skirting and walls. Thinking weather related issues on the exterior wall wether this could lead to problems
5 REPLIES 5
gg30340
Message 2 of 6
Re: By phone line ext
If you are referring to a telephone extension cable a good quality cable should not have any immediate problems however the outer plastic may eventually break down because of sunlight although this will take years.
If you mean an Ethernet cable, you can get external grade Ethernet cable which would be the best choice.
Chapate1
Message 3 of 6
Yes a tele ext cable, I googled and you can get tougher exterior cables for external use. Thanks
imjolly
Message 4 of 6
are you intending to use the phone extension to connect the internet to the tv?
Devon_Dave
Distinguished Guru
Message 5 of 6
You would need to connect the TV to your router not your telephone line.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Keith_Beddoe
Message 6 of 6
@Chapate1
Who provides your phone and broadband connection?
