Message 1 of 4
Colour printer cartridge
Hello. This is probably not appropriate for this site as it is to do with printer cartridges, however I will post.
I purchased a HP colour cartridge  and as per instructions I took off the plastic strip over the cartridge head. Unfortunately I took all the plastic strip off including the one that covers the copper strip...yes I know...I'm a prat. I now have a perfectly good ink cartridge that will not work.
Any suggestions or would someone like it.
Thank you.
Ron
3 REPLIES 3
Message 2 of 4
Re: Colour printer cartridge
Message 3 of 4
Thank you. I have asked the question on the site you indicated.
Ron
Message 4 of 4
HP and Canon cartridges can be recycled at
Freepost RTAB-BGGE-RBYR, Recycling Centre, PO Box24038, Edinburgh, EH3 1DY
I got addressed bags for the purpose with my Canons.
